Bolt Down Air Compressor Or Not & Antivibration Material ?
427HISS
I've had my 60g Campbell Hausfeld Air Compressor for decades and I finally want to cut out as much noise as I can. I have thin carpet squares under each leg, which I think are 3. There are hundreds or more of types of pads I could use, soft rubber, hard rubber, plastics, shock absorbers etc.
The legs have hole, so should I bolt each leg to the floor or leave the compressor float ?
If so, what type of antivibration to use above and below the leg ?
mm08822
Anchoring it to the floor would require isolators way beyond the carpet you have. Anchors in contact with the steel legs would transmit into the concrete.
I would leave it as it. Mine has been on 2x4's for almost 45 years, only b/c I worried about water in a basement originally.
Unless you can relocate it, I'd leave it. Insulating it will impact heat dissipation.
tomshep
60 gallon vertical. Mine has 3 legs. I used two pieces of 4x4. I put the back two legs on one piece and the front leg on the other. That gave me more clearance to the valve at the bottom of the tank. The wood just sits on the concrete.
nadogail
Coronado, CA
my compressor has two rubber tires in back and two rubber feet in front, the rubber feet and tires dampen the vibration; yet still allow me to reposition the compressor so i can sweep the floor.
gtae07
Fayetteville, GA
The noise is coming from the intake.
This.
I put my old compressor on isolators from McMaster, but the real noise is from the intake. A good muffler there that doesn't restrict airflow will help but it's not easy to put together, especially when the intake isn't a nice round connection.
racecougar
Missouri
I went with these 6-1/2 years ago for my 60 gallon vertical. I did the typical pound-in studs and used Nyloc nuts, left loose to the compressor tank feet.
Spareparts
Lansing Ks.
I put mine on double up 6" square pieces of the thick stall mat from TSC, removed the drain valve, replaced with a 90 elbow a short 1/4" black pipe and then the shutoff valve, easy to drain. The compressor is a 5hp 80 gal tank that I got in 1996 from North Central Air in Downs Ks. They delivered it to my shop, unloaded it, sat in place, even wired it to my disconnect and started it up. I purchased the kit to quitened the noise basically a smitty glass pak muffler, muffler clamp (2) removed the air cleaner, placed the muffler on,clamped it and placed the air filter on and done. I can talk on my phone standing next to it with no problem. The total price in 96 was $1096.00.
RMERR
Northern CA
My 80 gal 5hp compressor sits on 4 squares of 1/4" neoprene. No affect on noise, but keeps it from "walking" around.
ArmyVW_GuyInTX
North of the Fort Worth/Dallas metro area
My big *** 80 gallon vertical IR (old enough to have been made in USA) is not bolted down. It relies on gravity and cork rubber blocks from 10+ years ago. No noticeable vibration or noise. The outhouse keeps the weather off it and and wandering eyes from any landscapers.
Jazz1
Thunder Bay On.
Bolted to the floor with rubber belting as isolator to keep it from walking around the shop…still loud!
Firebrick43
West central Indiana
I've read up a bit on those boxes. Sounds like they have quite a bit of insulative material, plus baffles, to mute the sound. I wonder what material(s) they utilize.
The biggest reason the compressors are quiet is not the intake silencer but the fact that the pumps are oversized and only turning 730 rpm. I have the an Eaton similarly designed without the box and it’s still very quiet.
racecougar
Missouri
That certainly makes a big difference. I know the dual cylinder 5hp/60 gal compressor (background of photo below) in the main shop is way quieter than the single cylinder 5hp/60 gal in the auxiliary shop. I don't have numbers handy, but visually, it spins slower and has a larger pulley at the compressor than the single cylinder unit.
SouthernIllinois
I have an 80 gallon, 2-stage Champion.
I bought a box of rubber floor tiles from Menards, used four of them and gave the rest away.
Not bolted down and it hasn't budged an inch.
For noise mitigation, it is in a tool / storage room closed off from the rest of the shed.
micromind
Fernley, Nevada, about 30 miles east of Reno.
That's one of the best compressors available. It'll outlast 2 or 3 big store models.
mikedodge
Mine is sitting on the pallet it came with, never had a noise issue with it.
I have another that will sit on rubber pads.
A lot of instructions mention anchoring it but to leave the nut loose. Which is probably to cover themselves if someone does something that might tip the compressor over.
leadfoot415
Livonia, MI
My 60 gallon 2 stage IR has been just sitting on (with gravity assist) 2 large school bus mudflaps. Works well, it's not going anywhere, and with a flexible 1" hydraulic hose connecting it to the shop black iron pipe, vibrations aren't an issue.
Mike65
Horse Pasture, Va.
I have a 60 gallon vertical Craftsman compressor that sits on some rubber pads & is not bolted down. I have had it for 3 years & it has never moved.
Worsedog
Central FL
Best thing I did was put it out in the lean to I added on to the back of the garage. It's still bolted to the pallet that it came on. And it doesn't walk around. Inside the garage you can't hear it run if the radio is on.
Rusted Nut
Northern Arizona
You could mount on thin fairly hard no too thick rubber pad, and then install a spring under the hold down nut. Cheap DIY version of a spring isolator.
gearhead1
NC
Like many others I left mine on the small shipping pallet it came with and been there for decades. It is also a Campbell Hausfeld 60 gallon. As someone mentioned, it makes getting to the drain valve easier.
The wood absorbs the vibration and the unit hasn’t moved. Vibration pads and/or feet are not wrong, but the wood pallet has worked perfectly fine.
I agree with others that bolting the unit down will probably not reduce the noise, the intake is most likely the biggest contributor to the noise.
gearhead1
NC
The key too silencing is not having a straight path to the intake I suspect. The ‘shelves’ concept may be the ticket if you want to silence. Maybe it is in conjunction with the volume of the muffler also.
gearhead1
NC
I find nerd material quite interesting even when it’s over my head. LOL
My first assumption of noise production would be the piston. Assuming most of us have piston compressors. To get the frequency of the noise (piston cycles), take the motor speed, figure out the pulley ratio, do the math to get the compressor speed. Since the piston goes up and down in one revolution, divide the compressor speed by 2. Get the units in “events” per second. This is how many times the piston is going up or down essentially. This is the frequency.
Then, you put the frequency in this formula as the WH and solve for V0 which is the volume. Build your muffler with this volume. I suspect this may be the volume of the silencer boxes on the compressors. Something like this is how they ‘engineer’ the solution instead of completely guessing.
badonk
Here's how mine is bolted down. It is pretty quiet but I don't think these pads really make a difference. It is the two stage compressor running off a 5hp motor w/ 3 phase 208v power.
