bluedog225
Good morning gentlemen,
I am ordering two dozen 1/2” hdg bolts to tie a stair landing to a concrete wall. The total material thickness, including washers, is 10.75” and 12.5”. The bolted material will be concrete, steel, and half of the bolts will pass through LVL.
The Portland Bolt website tells me that the threaded portion of the bolt will be two times the diameter +1/2 for bolts of this length. Therefore, the threaded portion on these bolts will be 1.5”.
I’m thinking of ordering the bolts 1” longer than the bolted material thickness. That should leave 1/2” thread embedded in the bolted material. And leave 1” for the nut. Which appears to be plenty for a heavy hex nut.
I’d like to get this right. Any thoughts appreciated.
