Bolt Storage
visualj
Clayton, WI
Finally got these done as I was working on them in between projects for my fiancé.
I needed a spot to organize all my nuts and bolts that were in bags, CD tubs, boxes and various other places. You know, like everybody else. ;)
I made the boxes up using some 1x4 pine with finger joints on the corners. The dividers are some 1/8 plywood I had laying around. The whole unit is made from the 1/2" and 3/8" plywood that, again, was in the stack.
I ended up having to use two of the drawers for 1/4" bolts, with the others for bolts up to 1/2" along with a couple for misc. stuff.
Then I put it on a shelf in my "cupboard".
larry_g
oregon
Great looking solution. I did something similar and for a drawer pull used some 1x4 ripped at an angle and glued/screwed on the front;
GALLERY]
lg
no neat sig line
V
visualj
Clayton, WI
That is downright beautiful! How do you pull the drawers out?
The drawers don't slide in all the way, they stick out about an inch from the case. I figured that way I already had a hand on the drawer rather than just a knob. Less chance of it slipping.
