Boltless Industrial Shelving - External Racks?
bulletpruf
San Antonio
Fellas -
My garage is full of industrial boltless shelving -
I could use some external L brackets of some sort to hang on the outside - something that I could use for storing lumber, hanging things from, etc.
Looking for something along these lines but set up to attach to the boltless shelves.
https://www.amazon.com/dp/B07CTFB2CD/?tag=atomicindus08-20
I suppose I could fab something up, but would be a lot easier to buy something. Did a few searches and no luck. Has anyone seen these?
Dustball
Hudson, WI
If the holes line up (34.5mm and 55mm), it'd be a piece of cake to bolt these on.
https://www.amazon.com/dp/B07WD2VDJB/?tag=atomicindus08-20
bulletpruf
San Antonio
How about attaching the hook to a boltless tie plate?
https://www.buyrack.com/tie-plate-for-boltless-shelving.html
Kevin
That would work, but I think I have a solution.
I went to Lowe's and picked up some similar hooks. I'll drill them in the appropriate spots and then run some carriage bolts thru them. Just need to get the right size carriage bolts so the heads fit in the holes in boltless racks.
Thanks
Scott
