Bolts ID
bluedog225
Texas
What would you call these bolts? And where would I find them? They have a fixed washer, a square head, and square nuts. Looks like 7/8 inch diameter, hot dipped galvanized.
I’ve got eight and I’d like another eight.
Thanks
BillK
Beautiful Southern Maryland
Probably someplace like Grainger or Fastenall ? I would say they are carriage bolts but carriage bolts usually have a square part to keep them from turning when you tighten them.
johnre
Portland, OR
Do you care that they look the same or that the flange is captive?
Just buy hex bolts and washers and be done with it.
And if it appearance matters, do as @PCustoms suggests and buy 16.
And FWIW - by my eye, looking at the gap in the deck next to the 14" mark on the rule and comparing to the bolt shank diameter, I'd say 9/16". Definitely not 7/8".
bluedog225
Texas
I was trying to match them for aesthetic reasons. I think they’re just old utility bolts. Maybe not made anymore. I checked out Hubble site but couldn’t find something with that integral washer. Not a big deal. thank you all.
Leaflessshadetree
Don't ask.
Most aren't flanged. Those look like they are flanged to me. I don't think it's a washer.
The one in the background doesn't have a flange. I'm guessing on most the washers are stuck under the head. Minor detail as far a asthetics.
These days hex heads will be easier to find but square heads are still made.
Codyboy
S.E. TEXAS
Good guess but likely not long enough.
Lineman’s Lag Wrench
Our bolts were 5/8 and 3/4 , 8" to 18".
For anything needing longer we used D.A. bolts (Double Arming) "all thread"
Never in 40 years have I heard of a lineman lag wrench. 1/2" Lags (hard heads) are driven in to a pole, not screwed in. I guess it could be used for removal but there are better tools that have more functions available. I always just used a crescent wrench or channel locks.
The less tools on my belt the better.
whateg01
doo dah, kansas, usa
If the flange isn't important or a washer can be added, square head bolts can still be bought, as shown by the links above. I still think they look too have an integral flange from the draft angle on the square part and what appears to be a small fillet where it meets the flat.
Miss the Pontiacs
Saskatchewan Canada
I was issued a similar lag wrench but never used one. The telephone pole was drilled and then a cross arm was mounted with the hardware required. I have some of the old zinc bolts but that is pretty well an item of the past. Where we live everything is underground with the exception of the towns and cities that were aerially served previously by pole leads.
Off topic but are you referring to something like these?
BurtEggley
Codyboy
S.E. TEXAS
The pic you posted is a J hook or Drive Hook.
Below is what we call a Hardhead. It's driven in with a BFH instead of screwed in like a regular lag bolt. This design is easier to drive and easier to remove.
