BONDO Major FU?????
Johnny Generic
35 miles NE of Pittsburgh, Pa.
What to do? Friend gave me a can of Bondo to use as skim coat over some foam sealant that I used to patch a rust hole in a rocker panel of my van. Opened can stirred up compound and applied to foam. Let sit for two hours. Went to sand down smooth. Not dry or hardening. WTF? Read directions didn't add hardener. Chit, now what do I do? Will it get hard enough to sand smooth over time? HELP! Thanks, Johnny Generic.
strutaeng
Dallas, TX
If you didn't know this, Bondo should not be applied thicker than 1/4". It's supposed to be used as a filler for minor imperfections, not to build and sculpt body panels. Otherwise it'll just crack and fall out in a few months... unless you are selling the van soon...
mike93lx
Richmond, VA
It'll actually crack regardless of him selling it...just changes who has to deal with the hack work
Firstram
****** repair for sure but, if it will pass the inspection for another year I'd do it too! It takes a lot of nerve for the state to make the roads that corrosive and fail a vehicle for rust holes in the fenders. Critical components excluded of course.
kwb
PNW
There is no fixing- just a mess to clean up and throw away.
My dad (who owned body shop) was using a glazing putty from a 8-10oz squeeze tube and didn't realize it needed to be mixed like normal filler. His guys did not let him live that one down for a while. Granted it was a newer product and he had moved mostly to the office but it still was pretty funny.
ZRX61
Solar Blight Valley, SoCal
If the mud is too thick to see through, you applied it before finishing the metal bashing part of the fix. 1/16in is plenty, try for 1/32in if you can't metal finish.
Sumboodie
AK
Yeah you better get it all out of there, it will stay sticky with no hardener.
Bondo over spray foam? Sounds like you worked on the 66 mustang I bought a few years ago. ;)
I did fiberglass bondo using masking tape as a backer on my truck. Looked decent and no more jagged edges on the rockers.
cgrutt
Evercoat Rage is good filler. They also make a "Short Strand" formulation that can be applied a little thicker as it incorporates fiberglass strands to make it hold up better. I'd seriously consider eliminating the foam and riveting a piece of sheet metal over the damage. Won't last a long time but should buy you another year or two.
ZRX61
I got rear ended in my brothers 65 fastback mustang and it knocked off the entire rear fender tail light area. After the horror and disgust wore off I was able to appreciate the artistic ability of who ever did it
Was sat at a red light one day when a car pulled up in the next lane & hit the pothole. A bondo frisbee that looked to be about 3in thick in the middle & 15in or more diameter detached itself from the side of the car & rolled into the intersection...
kwb
PNW
The fact it's a rotted out shitbox is not an excuse to commit half-assery ;)
Actually those are the perfect situations to learn proper execution, because starting out it isn't going to go to plan but the plan shouldn't have first step being spray foam on a car project.
NYBODYMAN
NY
As stated it will never harden. You are also wasting your time since you "fixed" a rust hole with spray foam and are trying to cover it up with body filler. It will rust and/or fall off all in due time.
andyvh1959
Green Bay WI
Yeah, um, I, er, can attest to the spray foam holding moisture detail. I decided to do some redneck spray foam/Bondo work on my 2001 Dakota pickup that I bought real cheap from a friend. Rust had already made its mark, and I figured I could at least make it look better. I did, and it did, for some time. But eventually the spray foam held the water and simply moved the rust zone.
What I did to minimize the rot was glue in plastic panels under the box fenders ahead/behind the the rear wheels to minimize road spray/salt to getting above and onto the fender well. That did slow the eventual rust expansion.
KansasArt
Kansas
I can empathize with the OP. Back in high school, probably 1980 I had a ‘72 dodge dart. Slant 6 & vinyl top. Had a fist size hole in the bottom of the fender, among some smaller others too. Asked my dad how to fix. He said put a screen on the backside and use some body putty on the front to fill it in. That’s the extent of my body repair knowledge. So I picked up some putty and went to work. Couple hours later dad came outside to check on me. What a good mess! Putty everywhere, in clumps. On the driveway, all over the fender, me…dad busted out laughing so hard! He then pointed out that little tube of hardner. Explained how I was supposed to mix a SMALL amount of putty with the hardner! My first & last attempt at bodywork! I have a good sense of humor so go ahead and pile it on me! 😂
Norcal
Without the hardener being mixed in the proper proportions the bondo will be a mess.
PCustoms
VT
Proper procedure is sprayfoam to fill the hole,some tigerhair and then Bondo.
Followup with a quick rattlecan and no one will ever know.
Sometimes you got to be creative to pass inspection in the northeast.....
Bert_
NW Iowa
I've got sheet metal zip screwed over the driver side rocker of my car. It's held up fine for 4 years now. Expanding foam just traps moisture and will rust through even worse in a year.
The Cobbler
Well, OP learned something about Bondo.
many years ago, an old friend filled his Ford Cube Van cab full of spray foam where ever he could get it to "deaden the noise and make it more comfortable to drive on long trips when he went hunting"
after about 5 years the thing was a mess of perforated rust everywhere he sprayed the foam .he learned a costly lesson too .
but for a quick fix, I would go for it, and as mentioned, cover it first with fiberglass . Bondo doesn't like water .
