I received this ratchet and the center piece is worn out. Oddly, it seems to be made out of aluminum which makes me wonder if it’s the original! If anyone else has one of these ratchets taken apart with pictures that would be awesome. I’ll add pictures later today of mine.Anybody ever seen one of these. Are the internals like the A700?
Thank you!Hello @Bill Nehrkorn and welcome to the site!
keep this link handy at all times!
and this one!
HERE is the big "Bonney" thread, but "4080" seems to be mentioned only a couple times. (use that "search" tab at top right - click the drop-down menu to search "This thread only", and enter "4080" in the box - no need to scroll through 149 pages!)
datamp.org is the "go to" place for patent information. You can search by patent number, date, OR manufacturer
Here's the datamp.org search results for "Bonney" - and it looks pretty skimpy. Whether the applicable patent number for your unit is shown there I can't say - I don't know the Bonney line well. Other members are far more conversant about Bonney.
USPTO - United States Patent and Trademark Office
and
Bonney at International Tool Catalog Library
and then lastly:
Run a search here (use the search funtion at top right) and simply search: "4080 ratchet" - you'll find more than a couple mentions of it.
I finally took it apart so everyone could see!🫤. Notice I have 2 ratchets, but only 1 works. The one I took apart has a hole in the center with a spring and ball that keeps tension on the underside of the slide selector. The selector also has 2 holes on one side with a smaller ball and spring in each hole for changing from forward to reverse. The 2 planetary gears are just placed in a little recess hole. The rest of how it goes together is fairly self explanatory.
The WD40 soak is a good idea. If it doesn't move maybe gently tap the top of the screwdriver whilst trying to turn it, sometimes the impact shock will free things up, but be careful not to mash up the screw head. Use a screwdriver made with the tang through the handle.I have an old Bonney rachet #4080 that does not work anymore. It was my Dad's and I would like to get it working again. Have you every seen one of these rachets? Any idea where I could find how to repair it?
This morning, I sprayed WD40 and got it to work however, I would like to open it up and grease the guts. I was able to get one screw off but the other one is stuck. Any suggestions as how to get the other one off. I soaked it with WD40 also in the hopes it will sink in and I will be able to get it out. If I can not get it out that way, what do you suggest?
