shamrock12
I'm wondering if there is a good book that cover the design, site prep, layout setup, etc. of radiant floor heating systems that you would recommend?
I guess the insulation took one of the largest bites out of my budget next to the pex tubing itself.
I have all the books currently available and have advised many on their relevance. Unfortunately it takes some experience to sort out a great book like "Modern Hydronic Heating" as it is a comprehensive text.
All proper radiant floor heating designs start with a proper room-by-room heat load, performed on dedicated software by an experienced designer.
The heat load dictates (or confirms) the type of radiant panel, effective design water temperature, tube diameter, length and flow.
Buyer beware. The many on-line companies have limited resources both in product and knowledge. Every shoe salesman will first put you in the shoe they have on the shelf.
. I can do it but, well, you get it! With a pro, you will actually end up with a "real" boiler with the on board controls to get the most out of the system comfort wise and return on investment wise.
