Borescope or Inspection Camera Recommendations?
MN_Runner
Did anyone try a low cost (aka cheap $10-$20 range) borescope/endoscope from eBay for automotive applications? If you had good results, which one did you buy?
What I need:
I need to see a free spinning bolt that is inside the frame cavity. Trying to figure out if a deep offset wrench will do the trick but cannot see what "nut" I am dealing with. The nut is inside the frame and spinning free but I can access that nut through a 1" service opening. No access issue on the bolt head since it is outside the frame. I just can't tell what are in the way preventing me from a clean access to the nut.
turbowoodworker
Apex NC
I needed one for a project and found the Craftsman woks fine. I'm not a professional so I don't need high cost/ high quality. Since buying it for the one project, I find I use it all the time.
IIRC it was around 45-50 bucks?
