Bosch 11205 rotary hammer drill - Manual ??
geomagno
Indy
Just bought an old used Bosch 11205 hammer drill but have no manual or bits for it. Would anyone have any info on this tool? Label reads "1 1/8 Rotary Hammer" so does that mean I need 1 1/8 bit?
Plan on using the chisel bits for this if I can find the right ones. Appreciate the help.
LXCam
It means it's rated for a max size if an 1-1/8" bit which is the largest you'll find in a SDS drive. Which BTW is what you need for bits.
Also I can't think of any SDS drives that Work as a chisel. The only ones I've ever owned or seen where the larger spline drives. But I guess they must make them since that drill has a impact only setting, interesting.
G
geomagno
Indy
Thanks. First hammer drill.
If anyone has access to a manual for this I would appreciate it.
PBCampbell
WV
After a brief search, it appears this doesn't accept "sds"(sds+), but spline shank bits. There may be an adapter available though.
G
geomagno
Indy
So, 3 types of bits for hammer drills: SDS, SDS max, and Spline?
And this 11205 only accepts spline bits?
LXCam
I think you're right. After hopping on a real puter and not my phone, the tip doesn't look like a SDS drive. OP, does the receive have a horizontal slide bolt that locks in place. The other way of telling is the reciever have female splines or two detent balls?
