Bosch 18v chargers
Tinkerer2
Central Florida
I have 1 2Ah battery and 3 4Ah batteries. Only have 1 each of the chargers. Can a 4Ah battery be charged correctly with the 2Ah battery charger?
matthew
I don’t believe there is any difference in the charger. Except that there may be some charger models that are quicker than others.
HenryAZ
MEMBER EMERITUS
South Congress AZ
Model numbers of the chargers? Do a search on your charger model and check out the specs on Bosch's web site.
I use primarily all Bosch cordless tools/batteries/chargers. I do not own any 2 Ah batteries, only 4Ah and larger. The basic charger that came with a couple of 4 Ah kits is the GAL18V-40. Its specs say it will charge any Bosch 18V Li-ion battery. I also bought a couple of their newer 4 Ah batteries that use the 21700 Li-ion cells, rather than the older 18650 cells. One of the two kept reading "bad battery" at the end of the charge cycle on the GAL18V-40 charger, but it was not bad. I took it off the charger, and the battery's LEDs showed a full charge, and it worked just fine in a tool.
I upgraded my charger to a GAL18V-160C. No more "bad battery" notifications, it charges fast, and has LED indicators showing the state of charge as it is charging. I only use that one now.
T
Tinkerer2
Central Florida
I have the following chargers:
BC660 for apparently only the 1.3 Ah that came with my drill
GAL 18v-20 that I can't find the specs on. Came with a 2.0 battery.
GAL 18V-40
I found my GAL 18V-40 manual. It appears to be ok with 1Ah through 8Ah batteries. No mention of the 1.3Ah so I'll just use the BC660 charger for that one.
I retired my 2.0 charger. This cleans up my bench a little. :)
T
Tinkerer2
Central Florida
Does everyone leave the batteries on the chargers and charging until needed? I don't use mine daily. If fact, I haven't changed a battery on my drill or impact in over 3 months. Both still going strong.
