Bosch Concrete Grinder/Surfacer
ColdBlackWind
Trigonia, Tn.
I have a ton of leveling to do. Is this tool rugged enough for extended use? Does the dust shroud capture most of the dust? I just fried a 10 amp Ridgid grinder using a cupped wheel. I think it ate too much dust. Any comments or notes from folks that own and have used this tool would be greatly appreciated. Part number is 1773AK.
LegacyIndustrial
deerfield, IL
ColdBlackWind: Using a cup-wheel to level a floor creates a ton of drag, causing the grinder to draw more amps and speeding up the degradation process of the motor.
Consider using a Diamabrush hand tool or perhaps look at using a "planer". Planers can remove a bunch of concrete material fast. When done you can feather it out with your hand-grinder.
If it has to be a hand-grinder buy a 7" model from Harbor Freight, brushes can be replaced and if it blows, throw it out and buy another. We use them and they work great.
Good luck!
C
ColdBlackWind
Trigonia, Tn.
Thank you sir. I am working in an area right now that is Really close to finished rooms and I hate to use a scarifier. I will try the HF grinder. I have a dandy 7"
cup wheel and was moving along well until the grinder puked. Going to use sacrifier on the big area. Will be in touch with you once I get the high spots down and start filling lows. YOu did say the epoxy that you add sand to likes a hard edge instead of feathering, correct?
LegacyIndustrial
deerfield, IL
In heavy duty load areas with "steel wheeled traffic" we prefer a no feather install.
For a garage where you will coat the floor with epoxy feathering is acceptable.
It is at full strength from 1/4" up. Strength is less, although still high compared to concrete, when installed less than 1/4".
C
ColdBlackWind
Trigonia, Tn.
Well the two HF 7" grinders came in today. I also bought a "dustie" shroud to attach a vacuum. Mounted the shroud and 7" cup wheel and commenced to grind down a high spot. Great dust capture and removal rate was great for about 5 minutes and then the HF grinder went up in smoke. Even at $45 per unit that will get expensive since I covered about 2 Square feet!! Any other suggestions? I have to remove about 1/4" of material in a 6 square foot area.
Shea
California
Wow... Are you leaning in on it when grinding? It doesn't require a lot of pressure to grind the concrete. It will go a little quicker over high spots if leaning it on it but that can burn up the best of grinders if you do that for too long.
C
ColdBlackWind
Trigonia, Tn.
Was using a sweeping motion like you would buff a car. Using some pressure on the wheel. Thinking the 7" wheel is just too much for the grinders to swing. Going to try a 5". This *****.
