Bosch GLL-55 Laser Level - trashed?
number9
Had it for a few years, been great. Got it out to use it yesterday and found the AA batteries had spilled their guts. I wiped it out / off, blew it out with air hose, and installed new batteries but nada.
Anyone ever sent one of these in for repair? Is it even repairable?
Walkers
Cave Creek Az
Unfortunately they (are not so cheap) disposable toys. Buy a new one. Personally, I would take it apart to see if it is just a bad wire to the battery case.
Clean the contact points with a pencil eraser or contact cleaner before you punt.
Tools4Me
Instead of mechanically cleaning the contacts, I usually neutralize and chemically remove the existing corrosion with ordinary household vinegar. Any type works. I put some on a Q-tip and dab it on the corroded contacts. It will bubble a little bit and react with the alkaline battery corrosion. If there's a lot of corrosion it might take a couple Q-tip aplications to neutralize and remove it all. Sometimes a little bit of the neutralized corrosion will remain in areas where it was thick originally. A fine pointed dental pick or a toothpick can usually flake it off easily. After you get everything as clean as possible, dry the contacts off and use another Q-tip to wipe a small amount of dielectric grease on them. This reduces the chance of the problem happening again and the batteries will also have the best chance possible of getting good clean contact. Then reinstall the batteries and see if it works.
80% of the time that's all I need to do. The other 20% of the time, I have to take it apart more to find and fix additional corrosion damage. This often includes shortening and resoldering a battery wire lead because the corrosion has traveled to and eaten through the end of one of the very small gauge wires.
  • Like
Reactions: LSU
Indexmill
Central NC
Do also look for a wire corroded off of a terminal. Solder it back on.
Again, the PSA: Both Duracel and Energizer will send you a check for the cost of the thing that was destroyed by their batteries leaking.
N
number9
I removed 6 screws on the bottom trying to take it apart but the only hold a plastic plate on the body of the tool and the housing appears to be glued together :rolleyes:
It’s not like typical green corroded crust, it’s a clear, thick liquid. I’ll try and blast it with electronics cleaner and an air hose and see if that does anything for it I guess.
Unfortunately the batteries were the off brand originals that came in it.
tarmy
Nor Cal
I had the exact same unit and same issue. I cleaned the contacts up and it works fine…years later. Now, I always remove the batteries after every use…
make sure the solder is still good on the contacts…and ensure the contacts are clean metal…good luck.
  • Like
Reactions: LSU
