paredown
A new thing for me. This compressor has had infrequent use although it is more than ten years old--I have mostly lugged my Porter Cable pancake around (marginally lighter).
I did a day's work with the Bostich--intermittent nailing--after not using it for months. Next day--it would not build pressure, and air seemed to be leaking from under the shroud. I didn't spend a lot of time on it, but took off the shroud, checked all the fittings (nothing seemed untoward). I tried it with the shroud off--and it worked fine.
Next day--back to the no pressure routine..., stuck it in the corner and thought 'later'
So I'm looking for the 411 of compressor repair--what is likely to be failing, what to test etc.
