Bostitch compressor and nailer kit - Is it worthwhile?
SouthernIllinois
My wife and I retired and will be moving to the midwest.
We have several changes we want to make to the house we are moving in to.
Specifically, we want to replace all the window trim and baseboards with 1' X 3" barn wood.
I have next to zero experience at carpentry but I think I can handle this but I don't have the tools.
I came across this set on Amazon and from a novice point of view it looks like a good deal that will fit my needs but I thought I'd ask ya'll.
  • 150 max PSI 6.0 gallon tank (22.7 L) and 2.6 SCFM* delivered @ 90 PSI pump, enable long tool run time with quick recovery for the air compressor combo kit
  • Compressor features long-life oil-free, maintenance-free pump for convenient use
  • BOSTITCH high efficiency motor for easy start up in cold weather or extension cord application [14 ga or larger, 50 ft. (15.2 m) or less]
  • 78.5 dBA** operational noise level for a quiet work environment
  • SB-1850BN 18 GA brad nailer drives 18GA brad nails from 5/8-inch to 2-inch
  • SB-1664FN 16 GA straight finish nailer drives 16 GA straight finish nails from 1-1/4-inch to 2-1/2-inch
  • 1/4-inch x 15 ft. PVC air hose includes fittings
cgrutt
I had that compressor a while ago when I bought it it came with 3 guns, the 18g and 16g Brad nailers and also a narrow crown stapler. The guns are great but I blew the compressor (piston/crank fell apart) I did the same to the same style pancake compressor made by Porter-cable. I've been using a Hitachi oil compressor for about 5 years and it's been much better. I like Bostitch air guns very much and have about seven or eight of them but the compressor didn't hold up. That said I'm sure it would be fine for relatively light use (homeowner projects). Price seems reasonable with the included guns.
legenddc
It will do that just fine but beware it’s LOUD. You’ll need hearing protection. I sold mine and picked up a California Air Tools 1 gallon one. I did use it to put up all my baseboard and crown molding before I did.
Don’t forget you’ll have to move it from room to room so the weight could be a factor.
Might be able to pick up some nail guns used as some people are switching to battery powered cordless tools.
SouthernIllinois
Thanks guys.
Which do you think would be best suited to 1" X 3" window trip and 1" X 4" baseboards - the brad nailer or the finish nailer? Like I said I have never attempted this before.
cgrutt
I prefer the 16 ga for trim but you'll probably prefer to fill nail holes. You may need to countersink some nails as well in a perfect world wouldn't need to but there's always a few that don't sink completely. Use the 18ga on any thin pieces or if you come in from sides on miter corners etc. Make sure you're using long enough fasteners to hit framing.
SouthernIllinois
Thanks - I appreciate the help.
The wood we will be using is old barn wood so nail holes may not be that noticeable. It's fairly "distressed" as it is.
cgrutt
In that case pay attention to the way you orient nailer with grain of wood it leaves an elongated hole (more rectangular than round) run the fasteners with grain (generally hold gun perpendicular to trim) and the holes may blend in better. Sounds nice good luck with it.
SouthernIllinois
Thanks again (y)
The Cobbler
That's a decent set up for what you want to do for sure.
I have a compressor like that one, it stopped pumping after lots of use. all it was , the discharge hose came off. the clamp looked like it had never been crimped tight enough. opened it up, recrimped it . used the same clamp even
908Jim
I got the same compressor (BTFP02012) during an amazon deal about 6 years ago and it's very loud. Not being my main compressor, it only get's used when I need portability and it has never failed me, but it's got limited run time. I think the same basic compressor is sold under several Stanley brands.
NakeDiesel
oklahoma
I have all Metabo guns, 18g Brad, 16g finish x 2, 18g stapler, coil nailer. Just bought the Metabo compressor and it's run great for my outside projects. I use my big compressor in the shop when I'm building bee boxes and frames in there.
I have the similar PC compressor kit, and these guys are all under rating how loud it is. I leave mine outside when I can, run a long hose. I now have a Calif Air Tools and it’s much nicer to be around, but keeping the PC for when I want to gang them up and sandblast. 😉😜
But I use the bigger gun for all my 1” molding, keep the little one for 1/4 round, streamline type molding, not the 4-8” tall stuff.
Leaflessshadetree
Don't ask.
I find that the compressors with cylindrical tanks are easier to carry around.
Senco and Rolair also have quiet compressors (I've never used a California Air). BTW: These compressors are as much as the full set you linked,
LOW1
ontario
I have had a Bostitch set for about 10 years and it has worked great.
I was happier with it after I replaced the hose with a more flexible one.
I am even happier with the Dewalt battery powered nailer I now have. its just less of a hassle.
But a portable compressor is a good thing to have around. I would bet that you will get more than your moneys worth out of it at that price.
