engineer2
Haven't used my Bostitch N60FN finish nailer in a couple of years. Pull it out the other day, fires a few nails and quits.
Air starts leaking out the trigger valve. Pretty common failure on these, so I figure I need a new one.
Took it apart and everything inside is lubed and moves.
Put it together, slight air leak around trigger valve, but it still wont't fire. IIRC correctly a leaky trigger valve can keep it from working?
Any tips on other problem areas? I want to fix it right the first time.
