This is a project I've had done for quite a while and just never got around to putting together a thread. (Funny how a 1 year old can keep you busy.)
I wanted to have a large rolling bench i could use around the shop. This came to that and it ended up a little nicer than i originally planned.
The base is all made from lumber salvaged from tearing down my old garage. Original plan was to use (2) 3/4" sheets of plywood for the top... But came across a deal on the bowling alley that was too good to pass up. The wood was stained special walnut and rubbed with tongue oil, so it could be easily re-coated if need be. The work bench kind of turned into a test run for the dinning table i need to make... I think it turned out great and has gotten quite a bit of use already.
