box and pan brake capacity
that-guy
NoVA
i have been searching around for a box and pan brake for a while now...i am noticing that they all say that they can bend up to ** gauge mild steel across the full length of the brake
so does this mean that it can bend thicker among a shorter length?
rsanter
visalia ca
Depends....
Some that say 16ga can't seem to even do that very well ( think made in china)....
If you are trying to bend a narrow piece if a few inches and do it near one side or the other then yes you can get away with that
Bob
ilovevocs
Toledo, Ohio
Most 16 gauge brakes I have used including my own require a tremendous amount of effort to bend 16 gauge, To the extent that I don't bend 16 gauge in mine unless im forced to. The exception to this is my cnc controlled (16 gauge capacity) brake that bends 16 gauge with ease, and when its down and I have to use the manual machine it stresses me out. I can tell you that exceeding the brakes capacity on a portion of the brake will wear the dies quickly, causing them to round over and deform over time. I don't know what your folding or the thickness but if you intending on exceeding the published capacity or bending material close to it on a frequent basis I would be looking for a press break or a leaf with better capacity. This has been my experience, others may vary.
The thicker the material, the more of an offset you need between the lower die and the upper die. Thicker material requires a larger bend radius and that is how it is achieved. At some point your going to be forming your radius and not bending it. Creating a stress riser at he bend.
