Box Joint Jig Question?
seagiant
Hi,
Going to make a Box Joint Jig, the back board will be adjustable to get the Pin tightness correct but the question is...
How do you correct or center the Pins to be equal top and bottom on the finished board?
I see it as either changing the dia. of the cutter or the width of the board.
Trying to keep from having a thin Pin on one end but every Pin and Socket equal???
jar944
Northern VA
Hi,
Just adjust the overall size of the board to match the full pin spacing, same as machine cut half blind dovetails.
Jgaz
If I understand your question, it would be accomplished as @jar944 says.
But in my experience, it is quite difficult to get an exact full pin on both ends of a board especially if the board is wide.
Difficult enough that I almost always start with a board oversized for the project and designate one edge as the “waste“ edge.
I trim it to the desired size after the joints are cut or even after the box is assembled.
Jgaz
You can see on at least one side of this project I’ve marked the waste side right from the start.
The problem to getting a full pin is that although the pin may be an accurate 1/4” there is a very small clearance between the pins that would be very difficult to account for.
For a project the size I’ve shown I will set the tolerances just a tiny bit looser so that it goes together smoothly during glue up.
seagiant
Hi,
Thanks for the info and pics!!!
Wanted to make sure, I was not missing anything!
seagiant
Hi,
Nice work!!!
Jgaz
Hi,
Nice work!!!
A lot of talented people posted in that thread.
My box joint jig was home made from WoodSmith plans I’ve been very happy with it.
PCustoms
VT
I started making a box joint jig years ago, and made a drawer or two. After my second jig and the frustration of getting things perfect, I considered buying one.
Then I spent $50 on lock miter bits and setup blocks for the router. Very strong and (almost) foolproof, was a much better solution for finishing the kitchen drawers.
Maybe someday when I'm playing around I'll blow the dust off the box joint jig and try again
PCustoms
VT
I have a friend that does all of his joints on his CNC mill. I'm his defense, it does make it easy to get everything just right.
Does he cut the perimeter of the wood too? Otherwise it gets to be a PITA to align everything...
Used to have access to a few machines, IIRC the big one was 5x12'. Was interesting to make almost anything an interlocking puzzle out of full sheets of plywood. Plenty of bins, tables and other useful structures came off that
whateg01
doo dah, kansas, usa
It's NBD to indicate the workpiece.
Firebrick43
West central Indiana
The incra ibox jig works wonderfully and compensates for any cutter width with a unique double lead/double direction screw.
I have cut 30” long joints that fit the same on either end of the joint. It also eliminates fiddling with dado stack to get the exact width as the ibox adjust in seconds to what what ever the cut width is.
PCustoms
VT
This is the one I looked at years ago.
Nice, but $$$
PCustoms
VT
I personally prefer the look of a nice 1/8" or even 1/4" box joint over dovetails for drawer boxes Gluing them up on the other hand is a monumental pain. Half blind dovetails are just so much faster to cut and assemble.
I don't usually compliment a man on his drawers...
That's quite the stack
Jgaz
I wouldn’t make another box joint jig after all I’ve read about the Incra Jig.
Also I use a dedicated box joint saw blade set from Freud.
It will cut 1/4” or 3/8” joints, it’s waaay easier than trying to use a dado stack.
Mike65
Horse Pasture, Va.
I made a homemade box joint jig from plans I got from Norm Abram on The New Yankee Workshop & attach it to my miter gauge.
