YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 495
Whenever I bleed brakes with a hand pump, I ALWAYS get bubbles. Someone has told me that this is unavoidable, because air is introduced through the threads of the bleeder valve when it is loosened, and that there's not much you can do. I have heard some people put grease around the valve, and this will solve the problem. I figured I would give this a try. Is there a certain type of grease I should use or not use? Could some of the oils from the grease seep past the threads and enter into the brake fluid within the calipers, is this a problem, mixing grease and brake fluid?
