Are the one-man brake bleeders worth the money for occasional maintenance? Some with pressure tanks run into the $200-$300 range. I'm just looking for something cheap so I don't have to scream at the wife when she lets off the pedal too soon.
samkblam said:I have used the MityVac one man vacuum system to bleed my brakes. It was around $30 at AutoZone. Worked well.
I will agree with this one. Great tool.tomstin said:http://www.motiveproducts.com/index.html works well for me
kgwld1 said:I have the snap on one man bleeder. It was pricey but boy does it work slick. I do all my cars once a year since it's so fast.
I've got speed bleeder and a Mity Vac, but I really want one of those ^Vincent Vega said:I will agree with this one. Great tool.![]()
I had a friend who had a garage he did numerous brake jobs on termite trucks. He had them on jack stands and put a cookie sheet shallow pan under the bleeder. He opened all bleed screws and filled the master cylinder. He checked every hour after about 4 hours when they started dripping he would close the bleed screws. Not every one would drip at once.
I've used a new pump squirt oil can and put some small hose on the end used a box wrench opened the bleed with the hose on and pumped until brake fluid ran into the master cylinder. After all 4 are done I usually do one quick bleed to remove any air by the bleed screw.
Note don't use an oil can as oil will damage the seals.
