brake caliper tool
lightning02
Lang or Lisla when it comes to brake caliper press/tool??
which is better and why??
metaleltr
Western Ohio
Lang, rebranded by every tool truck, I like it, works great for dual piston, have not had chance to try it on a 4 piston, my Mac dealer said it may not fit the rears on some jap cars though
L
lightning02
iv read somewhere the tool sometimes is to thick and doesnt fit inside the caliper
I bought this made by OEM from Pep Boys and it is complete junk. Don't waste your money. Get a better model. The threaded rod bent under the stress and now it doesn't thread properly. I'll keep using my c clamp, thanks.. https://www.pepboys.com/product/details/8805221/00277
no. wont be buying anything like that lol
MLB0611
I own both, mostly use the lisle tool over the lang mostly due to speed
anndel
Hawaii, USA
I bought the Lisle hand pump single piston and the screw version but none of them worked because the piston still needed to be compressed and the tools reached their limits. I had to use a 8" C-Clamp to finish the job. On my next brake job, I just went for the C-Clamp.
rayh91
SoCal
I mostly use big Channel locks or Honda's OEM tool for 2 or more pistons. It fits in most fixed/Brembo style calipers. If not then I just turn it sideways and stick it in there.
I don't have a picture of it but it's pretty stout.
astroracer
Mid_Michigan
I have been doing this stuff for 40 years and have never used anything other then a piece of wood and a C-Clamp... Works great on 1, two and 4 piston calipers and is practically free. :)
Mark
crab
most of the time you can compress the piston with a pry bar before you take the caliper off. When that's not possible a C-clamp works best.
L
lightning02
All I use now is the c-clamp. Just thought something out there was worth buying to.
90zcar
I have the blue point rebranded Lang one. Honestly tho if I would redo it I would just stick with a c clamp and saved the money
lukedwag
Harbour freight has a great knock off of the snap-on one that does the twist in rear calipers as well. It's a great unit for 30 bucks
wil
massachusetts
A new use for an old tool:
Just at the right angles to use before removing disc calipers. For those rear discs with the screw adjuster...not so much
whateg01
doo dah, kansas, usa
I often end up putting the old brake pad on the piston side and pressing against that. I haven't had a set that I couldn't compress that way. I have the screw type Lisle. It works, but is slow. I didn't think that the brake system would want me pressing the fluid back much faster anyway.
Dave
Rich.
Newcastle, Uk
This is the best tool i've used so far for caliper pressing, takes less than 5 seconds.
Laser tools 5543
Rich
shockwave
Marietta,ga
I have been using the regular lisle screw in that works fine on both single and dual Pistons much quicker than the pistol style lisle ones that get bent on stubborn Pistons
But makes sure to get the ones with gold fittings new ones are silver and much thicker and cannot compress piston on rear brakes as easy
DHCrocks
Hawaii
I use an irwin quick clamp and a piece of scrap plywood. works great and doesn't cost anything.
brownsmustang
SWMO
A screw driver between the outer pad and the disc works great and is nearly free.
Sent from my SM-N910V using Tapatalk
jeepinerdeep
South Central PA
I use the lisle single screw type on single piston like my Jeep. I also have the Lang and found it works best on the bigger 3/4 ton trucks like my Ram. There is room for both types in my box.
