decableguy2000
- Joined
- Nov 4, 2012
- Messages
- 658
Brake line on our 03 Expedition rusted thru. Need to make a new one, would the HF stuff get me thru the job? Looking at the bender, former, and Maddox flaring kit.
I think that most of the problem I had was because I was trying to flare an existing line over the front crossmember and even though it was pristine, was not in an ideal position. And since it was only another four feet and two bends to the distribution block, I blamed the flare tool and bought more line. When finished, I tried to flare a piece of steel line I had removed, and it didn't make the bubble, but might have on a NICOP.Is it the flare tool, or operator error? I have the ATD kit which I'm sure is rebranded all over, and have not had a problem with it. Lining up the initial line depth for the first flare is critical. And by all means, remember to put the union on first.
Those style flare tools really do **** and break all of the time.Is it the flare tool, or operator error? I have the ATD kit which I'm sure is rebranded all over, and have not had a problem with it. Lining up the initial line depth for the first flare is critical. And by all means, remember to put the union on first.
It does and it makes it easy to flare lines that are still on the vehicle too. Super easy to use.I hear the style mikedodge shared work awesome.
Make sure you use a double flare on your brake lines, single flares are fine for a lot of things but not brake lines.Brake line on our 03 Expedition rusted thru. Need to make a new one, would the HF stuff get me thru the job? Looking at the bender, former, and Maddox flaring kit.
Much faster than making the lines.Plus you do not have to mess with them anymore since they are stainless steel or Nicop.We do it this way with the 1999 to 2006 GM fullsize trucks and 2000 to 2006 GM fullsize suvs
NAPA will sell you pre-formed brake lines for you application. NO those brake tools you mention are very difficult to use, even for a mechanic with decades of experience. The premade lines are inexpensive and may cost less that buying cheep tools.Brake line on our 03 Expedition rusted thru. Need to make a new one, would the HF stuff get me thru the job? Looking at the bender, former, and Maddox flaring kit.
A job that doesn't leak is a job well done. I don't consider brake lines a "good, better, best" situation. They either work or they don't.NAPA will sell you pre-formed brake lines for you application. NO those brake tools you mention are very difficult to use, even for a mechanic with decades of experience. The premade lines are inexpensive and may cost less that buying cheep tools.
I have made hundreds of brake-lines up with good success, but I have the professional tools. A grand is close to what a person needs, in tooling, for the best job.
