Brand new snap on and other stuff
JKJEEP2012
Enterprise, Al
OLYMPIA, WA
Snap on wrenches, sockets, extensions, and then some
I have the following stuff for sale. I can send you some pics if you want them. I can only post a few here.
For paypal payment add 3% or send as gift. Better deals on multiple items. Thanks
Shipping is calculated based on where you live
I currently have:
SRPC105 - Retaining Ring Pliers Set $85
PL400B - 4PC. Pliers/Cutters Set $115
SOEXM710 - Set, Wrench, Metric, Combination, FLANK DRIVE® PLUS - $275
212FSMY- Set, Socket, Metric, Shallow, 6-Point (12 pcs.) (8 to 19 mm) $115 SOLD
212SFSMY- Set, Socket, Metric, Deep, 6-Point (12 pcs.) (8 to 19 mm) $170 SOLD
PL300CF- Set, Cutters/Pliers, 3 pcs. NEEDLENOSE, SIDE CUTTERS, & SLIP JOINT $80
PL6711A- Set, Pliers, Needle Nose, 3 pcs $ 110
PL803A - Diagonal Side Cutter Set - $85
305ASX- Set, Extension (5 pcs.) (2" to 11" lengths) 1/2" DRIVE $130
SGDX40BR- Set, Screwdriver, Combination, Mini Tip, Flat Tip/PHILLIPS®, Soft Grip, Red (4 pcs.) $32
103UFTS- Set, Universal Joint, Combination Drive (3 pcs.) $115
SOEX707- Set, Wrench, Combination, FLANK DRIVE® PLUS, 12-Point (7 pcs.) (3/8" to 3/4") $150
206AFX- Set, Extension, Friction Ball (6 pcs.) (1 1/2" to 11") 3/8" DRIVE $115
HSG319- Hacksaw, Bi-Mold Handle $25
106BTMX- Set, Extension, Knurled (6 pcs.) (1 1/4" to 11") 1/4" DRIVE $82
212FMY- Set, Socket, Metric, Shallow, 12-Point (12 pcs.) (8 to 19 mm) $110 SOLD
AWP404- Set, Pliers, Adjustable Joint, 4 pcs. $110
FHBF80- FLEX HEAD BENT HANDLE, RATCHET 3/8" DRIVE $100
FHF80- FLEX HEAD, RATCHET 3/8" DRIVE $90
211SFY - Set, Socket, Deep, 12-Point (11 pcs.) (1/4" to 7/8") - $180
SGDX80BR - SCREWDRIVER SET, 8PC FLAT/PHILLIPS HEAD COMBO - $110
OEXM707B - WRENCH SET, BOX AND OPEN END, METRIC 7PC - $150
SF80 - FLEX HEAD HANDLE, RATCHET 1/2" - $125
SGHBF300A - 4 PC SOFT GRIP HAND FILE SET - $70
I ALSO HAVE:
FLUKE MULTIMETER 27- $135 COMES WITH TEST LEADS, MANUAL, AND CASE
http://www.myflukestore.com/p1240/fluke_27.php SOLD TO DOUG.J
White Dial Caliper, Hardened Stainless Steel, 0-12" Range, .001" Graduations
MODEL# 120Z-12 $240 Comes W/ Wood Case ($358 MSRP) SOLD
SUREFIRE E1B TACTICAL FLASHLIGHT: $100 SOLD
PELOUZE TMP2000 THEROCOUPLE THERMOMETER- $100 SOLD
PELICAN HARD CASES SIZE: 1450 ($65) 1620 ($170) 1660 ($240)
BENCHMADE AUTO PRESIDIO SBK5000 KNIFE MSRP$255 - $180
GROVES 62,500LBS. RECOVERY STRAP 30' LONG- $100 plus shipping (weighs about 30lbs)
http://www.sling-link.com/fire-rescue-gcvrs
I have for sell a new in the case (Pelican Case IM2500 W/ Foam) STANLEY PROTO 3/4 inch drive socket set. Comes with sizes from 7/8 all the way up to 2". Below is a list of what it contains. Not included in this list is an 18 inch Tee Handle and one of the smaller extensions, but they are included. The link below is for a set that has two less pieces. Asking $500 plus shipping
http://www.toolup.com/proto_j55200_3...LAID=780492133
5528 3/4" Drive 7/8" 12-Point Standard Length Hand Socket
5530 3/4" Drive 15/16" 12-Point Standard Length Hand Socket
5532 3/4" Drive 1" 12-Point Standard Length Hand Socket
5534 3/4" Drive 1-1/16" 12-Point Standard Length Hand Socket
5536 3/4" Drive 1-1/8" 12-Point Standard Length Hand Socket
5540 3/4" Drive 1-1/4" 12-Point Standard Length Hand Socket
5542 3/4" Drive 5/16" 12-Point Standard Length Hand Socket
5546 3/4" Drive 1-7/16" 12-Point Standard Length Hand Socket
5548 3/4" Drive 1-1/2" 12-Point Standard Length Hand Socket
5550 3/4" Drive 1-9/16" 12-Point Standard Length Hand Socket
5552 3/4" Drive 1-5/8" 12-Point Standard Length Hand Socket
5556 3/4" Drive 1-3/4" 12-Point Standard Length Hand Socket
5558 3/4" Drive 1-13/16" 12-Point Standard Length Hand Socket
5560 3/4" Drive 1-7/8" 12-Point Standard Length Hand Socket
5564 3/4" Drive 2" 12-Point Standard Length Hand Socket
J5649 3/4" Drive Standard Length Pear Head Ratchet
J5661 3/4" Drive 8" Standard Hand Socket Extension
J5663 3/4" Drive 16" Standard Hand Socket Extension
Syndicate
And thus U now know the REASON your threads get deleted. You constantly bump them with answers that should, and could, be sent via a PM (private message). I could care less about it myself, but that is your answer. Just ask WrenchR he is in charge of classifieds, he will fill u in.
