Brass adapter to attach garden hose fitting
branimal
I need to attach a female style garden hose attachment to a nearby water supply (NYC Apartment - no access to a hose). My bathroom sink cold line is a male 3/8 compression style fitting. I went to home depot and got a 3/4 x 1/2 bushing and a 1/2 x 3/8 FIP fitting. (1st pic). But the 3/8 FIP fitting wont thread onto 3/8 compression fitting. It's a different thread type. What can I get to make the connection?
Another option is to use a compression style adapter and connect directly to the clear tubing for the water connection (2nd pic). But I can't get the ferrule into the tubing.
wssix99
Chicago, IL
Go back to HD and get an aerator adapter. They have all sorts of them. They screw into the aerator and leave you with a hose connection in addition to the aerator.
^ This also gives you hot + cold.
If you want a more permanent hose, underneath the sink a garden hose is going to be overkill and (as you have found) you will need to do some plumbing. You can go with a smaller hose, like off a sink sprayer. I needed a setup like this once in an apartment a long time ago (I can't remember why.) but made a small hose that screwed into a tee that I added on to the compression connector under the sink.
branimal
The bathroom sink isn't installed right now. But there is a stand alone bathtub with a tub filler in the bathroom that's functional - will the aerator adapter attach to that?
Leaflessshadetree
Don't ask.
You can get adapters that replace the aerator on many faucets. There may be a couple different sizes.
To connect to a 3/8 male compression fitting you need a 3/8 female compression fitting which typically will be on a hose, Cut the hose and insert a barbed fitting with 3/8 Male pipe threads.
wssix99
Chicago, IL
Sometimes bathtub fillers will have internal threads so you can thread a hose in there. Most uppity brands won't have that. You can easily feel in there with your finger to see if there are threads.
Here is the hose I rigged up. I think its a dishwasher supply hose, around 5 feet long with 3/8" fittings on each end. They have rubber gaskets so they mate up to compression connectors. I then added a bunch of brass of the shelf from Home Depot to add the valve to control things. (I just remembered we had a very large humidifier and had to fill it with 5 gallons of water every other day, so we rigged this hose up to do that conveniently without needing to use buckets and make a total mess.)
mike93lx
Richmond, VA
This is my setup to get from 3/8 comp to 3/4 MHT. In this case, it's a 18" hose so I can use a pressure gauge and see it outside a base cabinet. The hose is 3/8 comp to 1/2 comp then the adapter is 1/2 MIP to 3/4 MHT
wssix99
Chicago, IL
BTW - If you need a real 'garden hose', I think you will be disappointed with anything coming out of a compression fitting. The water still needs to go through that small oriface and you won't get anywhere the flow you do out of a real garden hose. (If you use a 3/8" hose, like the one I made above, you are going to get close to max.)
Although, if flow isn't important for you and the garden hose is, some dishwasher hoses will have a 3/8" compression connector on one end and a bona fide hose connector on the other:
Let us know. We'll hook you up.
Also curious to see what you need the hose for. (We're hoping its for wet t-shirt contests on the balcony, but I expect you are going to tell us its for something else.)
