acer66
Hey,
You are looking at a around 7year old brass fitting on the lower right the left one is just for comparison.
I am on a well with a lot of iron sediments with various different types of filter throughout the years.
Water was tested over the years and checked out besides the sediments.
The only thing I noticed over the years is that when I installed the current water filter about 2 years ago wich is one of those big freestanding self flushing ones is that the water is harder and leaves those white rings.
Not sure how a filter could cause that.
This particular fitting is at the end of the drain line of a NC tankless water heater.
This shows the fitting in the position it was installed.
The water drained into the fitting from the right.
The fitting shows some damage on the right intake side.
This shows the pointing down part of the fitting from the first picture from a different angle with pretty severe damage.
Question now is this problem caused by the water heater or a water in general.
Thank you.
This shows the pointing down part of the fitting from the first picture from a different angle with pretty severe damage.Question now is this problem caused by the water heater or a water in general.
Thank you.
