Breathable epoxy??
Luckydevil
Tampa
From the looks of it they put in some additive initially and then it evaporates and lessens the bubbles from installation. So the floor would not still be breathable once it has dried and the additive is gone.
I think... :headscrat
G1K
Buffalo, NY
The answer is yes, you will have lots of little holes, but if as advertised (or my intrepretation is correct) the holes will be so small you won't be able to see them. They will allow moleculear levels of water to pass through. I'd be concerened that if water can come up, it can also go through, as well as other compounds with a smaller molecule size than water.
Ryan
