I was hoping to get a little help
I'm needed to sand my floor because its been several weeks between the last coat and the top coat.
I went around the edges with a palm sander and might have ended up breathing a good amount of dust. Any harm done?
I need to do the larger area and was gonna rent a floor buffer and screen. Does that work ok?
I had to fix a few areas and ended up coating new epoxy over a small area of already cure old stuff without sanding it first. Will this lift eventually?
Should I grind it off and start over?
Thanks!
Thanks!
