edl
another thread about part washer solvent got me thinking about breathing gear around solvents - one recommended solvent is Graymill Super Agentine
the msds says:
interesting bits from Graymill's MSDS sheet:
"SECTION VIII - CONTROL MEASURES
RESPIRATORY PROTECTION (SPECIFY TYPE): NONE
VENTILATION:
LOCAL EXHAUST:
NONE. SUFFICIENT VENTILATION IN VOLUME AND PATTERN TO KEEP WORK AREA
CONCENTRATION BELOW APPLICABLE SAFETY LEVELS.
SPECIAL: NONE
MECHANICAL (GENERAL): WELL VENTILATED ROOM
PROTECTIVE GLOVES: NITRILE
EYE PROTECTION: CHEMICAL SPLASH GOGGLES
OTHER PROTECTIVE CLOTHING OR EQUIPMENT:
FOR CONSTANT USE, NITRILE GLOVES AND SOLVENT RESISTANT APRON ARE
RECOMMENDED. WEAR GOGGLES AS APPROPRIATE.
WORK/HYGIENIC PRACTICES: USE SKIN LOTION OR CREAM IF GLOVES ARE NOT WORN."
So it appears that no breathing aparatus is needed (according to them) if there is "sufficient ventilation" - never have figured out what that is...
At the same time, the MSDS says that it contains VOC CONTENT: 780 G/L - aren't VOC's pretty nasty? - is this a really low amount?
What breathing/filtering equipment do you guys use with these types of solvents (e.g., kerosens, lacquer thinner, acetone, etc.)? - thanks! ED
the msds says:
VENTILATION:
LOCAL EXHAUST:
SPECIAL: NONE
