Long time member... First time poster.
QQ regarding weep holes in brick veneer. My brick sits on top of the foundation and as of late we've had a ton of rain. I noticed that in one of my rooms there is water damage to the wood floors. After checking everything inside for leaks as well as outside I decided to drill into one of the weep holes in my brick. I then stuffed some stainless steel (ss) wool into the hole and left it like that for a couple of days. After a good amount of rain the other day I went to check on the hole to see if any water was coming out. Apparently there was.
So after some research I found WhiteCap sells masonry weep hole w/wick tubes so you can insert into the weep hole to assist with drainage. I ordered one and after attempting to install, the cotton wick fell into the brick work, D'oh!
So, I had some cotton string available and more ss wool so decided to make my own kind of fix.
I fed the string in first using a bamboo skewer so that I could get it as far back into the brick work as possible, and then the ss wool followed and left some string hanging out to assist with water wicking/draining down the brick.
My questions are this. Will this work long term and should I have do this in multiple locations? TIA
