Is this thing on
Hello: guys/gals
I want to build a leanto shed thing on the side of my garage.
I plan on it being 8'x'24'x 6' at ends and 8' at peak, following the roof slope.
With 3 or 4 layers of cinder block, first layer level with ground as a base, and 2-3 layers above ground level ,then stick build.
The mortar used to build the brick layers, what steps are needed when doing this in winter temps, Do I need to add additives to the mix?
Plan is to try to get the brick part done if I can before spring if we don't get a ton of snow. but not sure if doing so in the freezing temps of winter will cause problems or not.
Thanks.
Thanks.
