pelletman
Can anyone tell me what the best way to put a VFD on a 2HP 3ph Bridgeport with Prototrak CNC control, if that matters. Is 110 1ph input OK or do I need 240? Or do I have to do a phase converter? Thanks!
Definitely do not use a static phase converter. Rotary is ok, but I prefer the clean power from a vfd.
Clean power from a VFD? What external filters are you using on the PWM outouts?
https://www.ctmmagnetics.com/the-basics-of-sine-wave-filters/
None.
Compared to the other back end sources of 3 phase power I find it generally to be the cleanest. Way better than no leg from a static and better than an unbalanced leg from a cheap rotary setup.
What is your recommended setup tool_scrounge? Details of your installs and necessity would help both me and the op.
Larry_g brings up a good point on the other 3 phase loads. The op will need to identify if other 3 phase loads exist. They vary may well, but it is also very likely the entire control is single phase and only the spindle is 3 phase. I have found this to be more the rule than the exception on knee mill conversions. A picture of the control panel would go a long way.
I say all,this as my shop is wired for both 3 phase and single phase 220, waiting to finish the rotary installation permanently through a panel. One thing I will say for certain is that the motor controls through a vfd are much simpler. Also, at work we have largely moved to vfd vs across the line start 3 phase for motors below medium voltage and even high demand starting loads. I’m a MinE not an EE, tool_scrounge should be able to fill in the details, I just get by with what works.
Here are some pictures, as you can see one of the X servos has a broken bracket. Anyone have any idea where to find one of those? Maybe I can tig weld it? I think the Prototrak has a separate 110V power source
https://photos.app.goo.gl/fVAsBGeJFJBqrcDH9
If the Proto trac is 120v for everything, servo drive, controller etc., You are good to go. Run the spindle motor on the VFD and make some chips. As far as the bracket, contact Proto trac, they may have one at a reasonable cost. Second, Ebay is a good resource. Third, repair it yourself. The tough part is after you weld it(?), machining it straight again.
Good luck, and keep the pictures coming as you get it going again!![]()
