Briggs engine cylinder wear...
jtbinvalrico
Tampa FL
I have the engine off my old Murray rider to replace the oil sump. I noticed some scraping/scoring on the cylinder wall....Anyone who can tell me if this is gonna be a big deal at some point?
It’s a Briggs and Stratton 11hp, 28C707 series....maybe 25 years old. Other than this oil sump I cracked near the drain plug (replacing this week), it runs fine. Inside of the oil sump was sludge free.
larry4406
Northern Virginia
Well it is what it is at this point. If it ran ok before should be no change after. Looks like it ran low on oil at some point (likely related to your cracked sump).
brownbagg
its 25 year old, if it goes tomorrow you got your money out of it
oldmxracer
You already know it does not look perfect !
Keep oil in the old girl and it can run for a LONG time !
kelpaso1
MEMBER EMERITUS
New Brunswick
Exactly. I don't know why some people here say Briggs are junk, but they are misinformed I guess. I've worked on some that are pushing 50 years old and never had an oil change:shocking: As long as they do have oil in them they are pretty indestructible.
c39er
Seattle, Washington
I still have my 4HP Briggs I bought new in 1966. I do change oil in these engines every 2-4 years and never have had a failure.
Good maintenance on things that should have it makes time to do other fun things in life.
Mr_B
Reading
+1 on this, I seen some old briggs that shouldn't really run great when see state of bores/pistons but they do .
I got 2 briggs from early 50's and both run great, one perfect, other been worked hard and oil changes minimal bore pretty bad and rod bad too, gave it set of chrome rings and new rod when started smoking and after bedding rings in it totally smoke free and runs and sounds, comp tests like new lol.
most horrors all down to poor servicing and years of abuse .
James-W
Southeastern Wisconsin
If the engine is one that you rely on to make a living, I would replace it. If it is an engine that you really don't care about all that much, then repair what is broken and run it for as long as you can.
