harvero
Well I finally got around to finishing up the sheet rock around the pull down attic steps I put in 8 years ago. I put these in when I first moved in order to store some of my parts in the attic. I had to open up the framing of the existing lift out access panel and I pretty much have ignored the fact the sheet rock needed to be patched for years. Well as luck would have it as I was climbing down the ladder after applying a layer of spackle to the repair the ladder broke.
Now I'm heavy, but I'm still at least 70lbs less than the rated 300 lbs.
I first I thought that I could rebuild the broken section with something a little stronger like oak. But maybe it would be better just to replace the whole ladder.
Since I don't want to mess with the opening I guess that I replace the steps with Aluminum model from Louisville that HD sells that rated at 350lbs.
