SMKS
Is this the 60 tooth model? I can't seem to find this model on the Matco website.
You may be right about it being broken. I may have to eat crow, because it looks like there may be a chipped tooth on the pawl. I pointed it out in these pics. It was probably already broken when you bought it, hence why it didn't work properly. I don't see how you opening it would chip a tooth on the pawl.
If this is a 60 tooth, then it should be the same as the 60 tooth Armstrong I have. My pawl has 11 teeth. Your pawl has 10 and a gap in the middle where it looks like one is missing. Unless the pawls are somehow different, it looks like it might be missing a tooth.
My 60 tooth Armstrong ratchet. 11 teeth on the pawl.
Your ratchet. 10 teeth on the pawl and note the gap where a tooth appears to be missing.
