Saw this from my local monthly machinist catalog sometime back. similar to the methods some of the ppl proposed, punch / drill/ and scrap out.
broken tap extractor
He broke a tap. You can't drill a tap out. It will either have to be burnt out, or set up and take a carbide endmill to remove it. If it's burnt out, it will be done by an ELOX machine.
Normally if a tap breaks, especially a 1/4" size, there is a tooth broke and is now binding. And chances are you used a four flute tap.
Sometimes the tap will shatter completely in half, but I doubt it in your case. If you don't know someone with a mill, and that has carbide endmills to eat it up, then check around some job shops in your area to see if they can remove it. You can try a tap extractor, but good luck with that. Sometimes you can take a small punch and hammer, and hit the high side of the tap to try and back it out. It won't go forward.
If you get to the point that you exhaust all avenues, send it to me and I'll take it out for the cost of shipping it back to you. Over the years that I've worked in tool & Die, I have removed thousands of broken taps.
And don't use four flute taps, especially in a through hole. Always use a 2 flute spiral gun tap. Way less breakage.....Guaranteed!!!
What type of carbide end mill should I get to try the chew up the rest of the broken tap.? I would try using a drilled thru 1/4-20 screw as a bushing/guide. I don't have a mill, only my 16 speed drill press. Based on your carbide end mill recommendation, what speed would you recommend? Thanks
given the size of the "carbide end mill" you will use....
and the spindle runout on drill presses
and that the tap is broken at an angle
and that tap drill size is 13/64" 0.203
you're looking at a 3/16" cutter MAX, think that'll take side load?
send it out.....way cheaper
One quick blast with an oxy /acet torch will remove enough of the tap to pick and punch the leftovers out
Don't take a torch to a Vee Block. That is just ludicrous. Sorry Kevinweg, but you don't want oxy/acet on precision tools.
BS. That's the safest procedure to remove a broken tap from a rifle barrel when drilling and tapping for a mount goes wrong.
Your way can make the hole deeper. The torch will not.
There is a big difference between a rifle barrel and tool steel for a hardened toolI've always puddled up a little mound on it with the TIG and then welded a short piece of 1/4" rod on it like a lever. A quick shot of kroil and work it free. Takes a bit more effort if its shattered, but still doable. Never had any that I couldn't get out this way.
See...that's the difference between a machinist and a mechanic. It's fine to weld on something like a broken stud on an engine block, but if you have precision machinist equipment, applying heat, whether through a torch, or through a welder can warp the tool. When it comes to machinist tools, you want them as close to precision as possible.
If one weld splatter got on the end of a Vee Block like the OP has, and the block was heated up beyond being able to hold it in your hand, it has been compromised. A precision Vee block has to be precise setting on the bottom or setting on the end withing .001 at least. Ideally you want squareness and parallelism withing no more than .0005 and preferably .0002
Success at last!!!!!
I decided to just pound the snot out of the rest of the tap. Initially after the break the tap seemed really hard but towards the end it seemed to morph more and not break into pieces.
Now, knowing that this is a hardened v block, if I wanted to clean up the threads, what type of tap would I use?
Thank you very much to everyone for your help. The BFH in the end sorted be out. Now what to do with the deformed punches....
Jody did a video this week on this very subject:
Why were you originally trying to clean up the threads anyhow, just out of curiosity?
It's always the inconsequential little niggles which bite you, ain't it.That's why I'm a great believer in walking away from something which is prefectly sound and functional these days, rather than trying to correct that niggling little quirk. It gets you without fail if you don't.
I agree. This was a very good lesson since I was thinking to myself that if the tap broke it would be a pain. But in this situation, I am not likely to use these holes so if the hole was really FUBAR, then the functionality would not be compromised. But in the end, it is good to figure things out ahead of time, ask questions first on forums like this, THEN make a move. The machinist that made these might be rolling over in his grave but...
Explain to me how a through hole is going to become deeper, and if the block is tool steel and not yet hardened, by torching that area, will make it hard. Then how are you going to finish tapping it.
I'm taking it that you haven't worked with tool steel much.There is a big difference between a rifle barrel and tool steel for a hardened tool
PT....are you a machinist, or training to be a machinist, or just a home hobbyist?
Home hobbyist. Just like to tinker with all things metal. I do thank you for your help with this issue.
No problem. That's what Garage Journal is all about....people helping people. We may not all agree at times, but in the end, things get resolved, and everyone goes to bed happy
If you ever need machining help, you can always ask me, AP is a fantastic machinist, and there are many others on here. So ask away when you feel a need, and you'll always get an answer, and many answers.
BTW....what sort of things do you tinker around and make? Any pics to post?
I've been wanting to ultimately wanting to get into knifemaking. I'm making a table that will flip my 2x72 belt grinder. It's powered by a 3phase baldor motor with vfd. I need to make a versatile work rest that will work in vertical and horizontal. I'm just so jammed up for space and time that things seem to have stalled. If I move to a new place, a home shop would have a mill and lathe. No ladies or dogs allowed.
