Flathead Red
I was putting a timimg cover on a 351W along with the water pump. I bought a set of three water pump bolts made by doorman. While trying to figure out which holes the bolts go into, I snapped one off. I got an ez-out from my local hardware store and drilled into it and snapped the ez-out off. After I calmed down, I researched on here about how to remove the ez out and the bolt. I got a couple of the tungsten and diamond dremel bits yesterday to remove them. Now, the hole is larger than original. My thoughts are to clean up the hole and retap with a larger bolt size but that will require resizing the timing cover/water pump. I also thought of a helicoil but have never used one before. Lastly would be to seek out a machine shop to fix it professionally. Any thoughts or opinions?
Red
Red
