Broken garage door spring.
redmondjp
Redmond, WA
I've done it myself with no drama. Yes, 100% focus is required while you are winding up each spring - one slip and it can be a lot of not good. You put rod in, loosen locknut, turn quarter turn, tighten locknut, move rod to next hole, repeat. It's a slow, steady process for each spring.
Springs should be tightened such that the door balances at the half-way open point.
As stated above, the hardest task is getting an accurate weight of the door.
Another tip: there is no one 'right' spring. You can use a range of springs - the longer springs (which cost a bit more) will last longer as they aren't as stressed per each up-down cycle. Builder-grade is the shortest spring that will work. I went a bit longer than original when I replaced mine. Yes, the wire diameter does change a bit with increasing length as well.
I also spray-painted a much brighter white stripe across each spring before installation so one can easily count how many turns are on the spring.
W
Woody610nb
Concord, NC
Thanks for all the input. I ordered the springs online and will do it myself. I also ordered the winding sticks, to do it safely.
My problem is that I am suppose to be retired, but I still work. I don't really make a lot of money and it is difficult to justify going to work for 3 days to pay someone to do something that I feel confident I can do myself. I'm better off taking off work and spending the day doing it myself. I am sure others have be in this situation.
NUTTSGT
Northern Central Ohio
:headscrat :dunno:
Home Depot does NOT sell torsion springs!
True, but I think that guy was talking about extension springs. Not sure why he was dragging that anecdote into a thread about torsion springs. Eh, we all miss a word sometimes.
On the contrary, HD sells both.
extension springs.
http://www.homedepot.com/p/Everbilt-160-lb-Extension-Springs-2-Pack-5020S16/202088379
torsion springs.
http://www.homedepot.com/p/Prime-Li...d-250-x-2-in-x-32-in-Green-GD-12235/202633649
Personally I don't care which one you're installing, use extreme caution, things can go bad before you have a chance to think or react.
upndown
Desert Hills/Peeples Valley AZ.
I stand corrected! I never even checked on line. When I go to HD I usually stop at the garage door section just to see what they don't have. I didn't see any thing but A few extension springs so I asked, guy told me they don't sell them because of past injuries. Then I watched him walk back to the paint department.:dunno:
dclassical
Good luck to you.
I installed mine about a month ago (one spring broke) and I am so glad I did it myself. Not much to it really, just stay focused when you wind them up/down. The spring are dangerous, just treat them with respect and think about what you are doing. Not much to it.
chops101
S. FL
I just did 4 springs on my two new doors. Quite elementary really. I took pictures and posted in my door install post. And I do all my frontend coil spring work myself on my classic restorations. You have to work smart, use common sense and stay focused.
