Amazon "warehouse deal" so I couldn't take it apart. Just sent it back but curious what could've happened, and if it's a common problem with these. Already ordered another one of the same. It had clearly been very slightly used, so could've been the first guy that broke it, or from the factory.
Sounded like something was loose inside, so figured there was something up with it, and when I tried to loosen a lug it had almost no power. Vid is at 90psi, my older IR impact worked fine so not a line issue. End of vid shows the rattling noise impact makes when turned upside down
