Bubba Fett
Well I walked into my Man Cave/Office, and noticed the floor felt weird. Also noticed my speaker towers were leaning a bit away from the wall, as is a chest of drawers which hold DVDs and Blu-Rays. I put a ball on the floor and it quickly rolled to the center of the room. Uh oh.
So I crawled underneath the house, and took a look around. I have 4 cracked joists, all next to each other. I reckon I had too many tools, speakers, CDs, etc. in there.
So I plan on filling the cracks with wood glue, and use a couple of jacks and an 8-foot 4x4 beam to lift the joists up all at once, then sister the joists with 2x8 boards. I'm planning on building new supports with concrete blocks to prevent this from happening again, using the 4x4 to spread the weight.
But folks, moving those blocks, and wood to the location is not as easy as I had thought. There isn't much clearance under there, and it's a hell of a lot harder to pick up a block while lying down. I did find the lower section of an old A/V cart, which lets me roll them, but the ground is uneven. Anyway, I got most everything where it needs to be, but I was worn out, so the actual work will have to wait.
Does this sound like a decent plan? Should I use gravel or quick-crete to make a footing before stacking the blocks?
Thanks!
Thanks!
