Broken key in lock
Macduf
Seattle
Exterior door on apartment building, broken 1/4 inch inside lock. Any good ideas ?
p_mori7
Montreal, QC., Canada
Take the knob or deadbolt off the door. You should be able to push it out from the back when the mechanism is exposed if I remember correctly.
M
Macduf
Seattle
Was thinking about pushing it out from the backside, but worried about the pins flying out like crazed ratchet rebuild
kckndrgn
Somerville, TN
I've seen my FIL put a small, very small, dab of super glue on the part of the key he had out, insert in the key hole, wait a few seconds and then pull the broken piece out.
If you don't have the other half of the key, try a small dowel or similar sized key with the glue.
Of I shouldn't need to say, but if you put too much glue on and it oozes out, you risk gluing up your lock.
marinusdees
Edgewood, Washington
Locksmiths use broaches. Try a local locksmith supply. Or, try a local endodontist. They use barbed broaches to extirpate pulps in vital teeth. A locksmith friend of mine tried dental broaches and was disappointed. Just an idea.
The Cobbler
as others have said get a small hardened pc of metal and try to extract it by pulling it out. a bit of wd40 or other lub will help it be slippery to make it easier to pull out.
or
get the lock apart, remove the tailpiece from it, and push the key out from the keyway, do not try to do it with the cylinder cap removed .
metalmagpie
Seattle
I suggest plumbing air to a really teeny hypodermic syringe, like a no. 30. Work the point as far in as you can and then apply compressed air *behind* the broken off part.
If that doesn't work, drill out the lock. A new lockset will cost you what, forty bucks?
metalmagpie
ar2stp48
Magnolia, Arkansas
"...Exterior door on apartment building, broken 1/4 inch inside lock..."
Remove the lock cylinder from the door. Standard knob lock, deadbolt, commercial with screw in cylinder---remove the lock to the cylinder alone. You can push the broken piece out from the back. The core will not come out and scatter pins; you said key was only 1/4" in lock, some pins still have it locked in place
No need to drill and destroy a lock. And I would not put super glue anywhere near the pins of a lock. If you were closer, I might suggest it---I would be assured of a $$$ lockout call. Just kidding
Key extractors work, but not readily available. Have a couple of sets of them; the single barb works best for me
dogdog
if you have access to take the cylinder out, then ram it back out from the other side.
if not, a dental pick ....
if the broken key is the correct key cut for that cylinder/lock. then try to push it in a little and pick the remaining pin that is not seated while turning it..... and then take out then cylinder ram it out from the other side....
Locksmith used those extremely sharp hooks made out of spring steel.. and try to catch it on the brass and pull... works sometimes, most of the time it doesn't.... at least I don't have any success with the few times I tried.
ducksface
Wd40 or silicone.
Rap the other knob with a rubber hammer.
It'll fly right out.
If it's a steel key, try a good magnet.
EOC_Jason
Bentonville, AR
Most keys are brass (so they wear instead of the pins).
If you can take the lock apart I would think that would be easiest to work with. Otherwise many posts above has some good tips to try.
isb cornbinder
I have used Gorilla glue to connect the broken key. In a few minutes I was able to carefully pull the broken piece out. I thought I was a genius until I told my locksmith friend and he said this is one of things he tries, first. Oh, well.
Mr_B
Reading
coping saw blade modded on a grinder makes a tool as good as pro key extractor in 2 minutes.
tiny bit of glue or epoxy can work but can make things worse so not what I would do first.
a long pin with end bent as small hook works good too .
