redm18
Greetings I will post a picture below. I recently purchased a late 80's Kubota 4200 HST garden tractor. It has a Z430 diesel engine. As part of putting it into service I have been changing fluids and other items on the book maintenance schedule. Last night I went to change out the coolant. It has what I assume was an aluminum petcock on the block to drain the fluid. I turned the petcock and noting came out. The petcock fitting had a hex head on it so I tried turning it with a socket. It broke off super easy. Still no fluid. I change. I changed the fluid by pulling the radiator hose. I'm trying to decide what to do now. 1. Leave the broken off fitting and hope the very hard corrosion/ crud holds the fluid in forever and keep an eye on it. 2. Try to drill out the fitting with a hand drill, tap it and put in a bolt or something to seal the hole. 3. cover the hole with some sort of JB weld or something similar and hope it holds.
