tlmartin84
Well I got it in a coat of epoxy primer and urethane satin black yesterday. Here are some pictures from the build. Now I just have to get it installed.
I started this out by studying various cages. I liked various aspects from each cage (Toms, KE, etc.). There were things I did not like, some were to narrow or too short. Another thing that drove me nuts, was the B pillar not matching the rake on the seat. And then the C pillar needed an opposite and equal rake for aesthetics.
I also wanted an overhead console with dome lights (hence the wires), I will detail this on the final install in an updated post.
I did not like the front A pillar bars going to the floor. I will add A pillar bars and the cowl plates similar to Tom's when I do the frame off in a few years. Right now I am afraid to disassemble to much as rust is all that is holding it together. HA.
I will also say I am a better Migger than a Tigger, but I figured this was a good opportunity to get some Tig practice in. So no, it is not perfect...critique all you want.
First I started with my bender and DOM tubing. This is my first go around with DOM. It took me a few tries to get the bends made without breaking the tube. I had to spend some time polishing the dies. The first task was the two main hoops.
The next step was getting the crossmembers in place and the base plates on.
Next was to weld in the other overhead supports and gussets. Then another test fit. I must took this thing in and out 20 times. I won't lie, after welding I still had to get out the torch and do some tweaking.....
I had my buddy cut these gussets for me.
Next step was the seat belt bungs. I reused 6 from my old cage and turned two new ones down on the lathe.
Lastly was paint! 3 Coats of Kirkers epoxy and 3 coats of Kirkers Urethane Hot Rod Satin.
I'll post some install pictures as soon as I get it in!
