My Brother contacted me for CAD plans (because I know several) and requested them by the end of the week if possible... I told him a should charge him a rush fee. Ha.
The site.
Flat, no grading needed.
Sticky clay that is wet weeks after rain and can have massive heaves. Vernacular architecture is pole barns and pier and beam houses.
No building codes or inspections.
Family ranch which is staying in the family.
Program.
Low cost, same or less than a $10,000 steel building.
Built by someone with some framing experience (built a greenhouse I designed).
"Movable" (As I am re-interpreting "temporary" and an aversion to a permanent foundation.).
10 foot high roll up doors (What for, have no clue as never would own something needing such height.).
20'x24' with two bays, one drive-through bay.
Parti
Low cost, simple construction and design, shop in keeping with the vernacular architecture of the community.
Talked with Brother and does not want to do a thickened slab as in his mind, means weeks of digging into the hard clay, plus also means permanent. The latter can't understand, though can't convince otherwise, even suggesting CMU block on the slab (again permanent and too much time). My concern is with the high walls, a lot of load on a four inch slab, especially with the soft soil when wet (and doubt any gutters so be even more water incursion). Then had the thought to use railroad ties like the greenhouse. Doing a search on this forum and other sources, seems possible.
Is setting onto a compacted bed of road pack and staked with rebar a good method?
Can the ties be form-work (like rat boards in a post barn) or is that going to cause too much horizontal load and spread the foundation?
Don't think Brother ever bother, just an out building, however, curious if the walls could be jacked and shimmed knowing good chance of settling.
Thank y'all in advance.
The site.
Program.
Parti
