Bryant 90+ Plus 2 stage NG furnace will not fire when vent line in the side of the gas valve is connected. Furnace is 17 years old.
Background:
Default code 14 ignition locked out
First code is 34 ignition proving fault leads to 14 after 3 fails.
The the igniter glows, pressure switch closes, cleaned the flame sensor but the problem is no gas flow on start up. Once it fires it runs fine.
Checked and double checked vent and fresh pipes. Blew and sucked more than once.
If I disconnect the vent line to the side of the gas valve unit starts and functions.
Picture show the line in question. This vent line connects the fresh air supply, the side of the gas valve and the switch side of the pressure valve.
I swapped the inducer blower with a spare as a test. Same problem. I was suspecting the pressure switch but now thinking no ????
After working on this and watching this for hours I am thinking the gas valve is failing.?????
[/URL][/IMG]
Brass fittin on the side of the gas valve. Removed and checked the little port on the fitting it is clear.
[/URL][/IMG]
[/URL][/IMG]
Green tape IDs line in question
[/URL][/IMG]
Background:
