Bubbles on a few year old RoboToolz laser level
RichTes
I've had a long time. Cleaned out the leaked battery but luckily just went bad and came out easily. Noticed the rear side to side bubble is dry.
Guessing the caps were pressed in from both sides and the little hole is an adjustment screw. Can't tell if that's the liquid from the bubble or there's some glue there too.
Probably not worth replacing, but I'd like to fix if cheap enough. The laser works.
Thanks.
You Can buy replacement level vials, you need diameter and length, and maybe precision level required.
Price goes from reasonable at HD to OMG at specialty houses. Price and quality may or may not be tied together.
R
RichTes
Thanks. I'm debating how to get out. Since it's already broken I should be able to push out.
I have a Starrett 199 level
