I put together the first few fittings, 3 ball valves, retractable air hose, filter and regulator. Everything looks good, I cannot hear any hissing of air and the gauge appeared to be holding well. I thought I would give it the soap bubble spray test and noticed there are bubbles from many of the fittings. I used brass fittings with teflon thread tape wrapped in the direction of the threads with about 3 layers of tape. When looking at the gauge on the compressor, I am losing about as much air in and hour as about a 2 to 3 sec blast with the air drill. When I check this forum, some seem to say that these bubbles and some leaking from the fittings is unavoidable, others seems to say there stuff is sealed tight like a drum. What do you guys think? If this seems abnormal, any suggestions on possible mistakes I may have made and how to go back and correct them?
Thanks
Thanks
