Buckeye Hill Shop Build
matt_i
Are the posts laminated? I am seeing some gaps in the top where I would not expect this with a solid piece.
jblnut
In the Middle of MN
Do a larger covered porch area while its skeleton is still sticking out !! I did a small porch/dry area by the door I use most and really really wish I’d have made it large enough to comfortably fit a picnic table, grill and have space to still be used as an entryway.
Just a thought. It looks great and it’s always very exciting at this point where you can see how big it is and start planning what to do with it !!
N
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
Porch is sized for a few chairs and a small end table for a 🍺.
And of course to cover entry for when it’s raining.
Don’t need anything bigger than that. Patio has all the stuff you mentioned up at the house.
N
NWOhioChevyGuy
Four more braces this morning & perlins on the porch and framing will be 100%
Took the weekend off and rode a "little" bike ride for Make-A-Wish Michigan
302.5 Miles with my wife and brother in law - Such a rewarding event & great communityIMG_2518 (1).jpeg
If you feel so inclined to support our fund raising throw in a couple $$
N
NWOhioChevyGuy
Need some moisture to finalize the compaction / concrete prep. Come on Mother Nature 🌧️🌧️
Had 1/2” last weekend = perfect, until the borrowed compactor threw a bearing. Got it fixed and ready for another shower!!!
Placed the stone back fill around the shop perimeter last night. 24” out, grade will be sloped gradually away from here with the soils removed at beginning of project.
My foam sheets were delivered Tuesday, was hoping to get them down before vacation - but compactor breakdown has prevented that from happening.
Still moving forward. Just slower than I had hoped for.
N
NWOhioChevyGuy
How are you guys installing baffles for vented soffits?
I’m thinking this approach, eventually I will install blown in insulation above my ceiling.
Want to frame this up before ceiling is installed (obviously)
So I came across a roll of reinforced vapor barrier that I had left over from my garage project and will be using that for my "baffles". I should have enough scrap / left over 2x's to make the bracing for supports.
Revised plan
N
NWOhioChevyGuy
That'$ a nice pile of foam!👍
Where's it going?
You're doing a nice job.
Under/around the concrete
25# will be placed in bulk of the building
40# will be placed width of the main door 32' in (just in case something HEAVY is worked on)
25# will also be placed vertically 8" at edge of concrete along perimeter walls to provide a thermal gap to the skirt board/exterior.
