Budget Epoxy Garage Floor Plan
cp3k
Hi all,
First timer here, and I would like your opinions on my plan to epoxy (w/ full flake) my 500 sqft garage. The garage was built in the 60's and I am new to the property, therefore have not seen it through the seasons. Moderate climate located in California, SF bay area. I intend on going a more budget-friendly route, while hopefully not sacrificing too much quality.
First things first, the epoxy I want to use is a 100% solids, cycloaliphatic coating. I want to use this for both the base coat and top coat. Is it a mistake to not use a moisture barrier? Will the lack of UV resistance be made up for by a full flake broadcast?
Items List:
My plan is to:
  1. Grind and clean floor, then apply crack filler.
  2. Apply first coat of light gray tinted, self-leveling epoxy using squeegee and roller
    • Can I use normal squeegee? or do I have to use a combed squeegee since its self-leveling?
    • Should the roller be spiked for bubbles?
  3. Apply full flake
    • Is this even feasible with just 25 lbs of flake? In an ideal world with no wasted flakes, how many lbs of flake for full broadcast of 500 sqft?
  4. Scrape and vacuum excess flakes
  5. Apply second coat of epoxy
I was also going to order an extra 3 gal of clear coat in case I was short. Please let me know if I have any major oversights or if you have any recommendations, I am completely new to this, but have spent a decent amount of time researching. Thanks in advance for the help.
