Would someone please interpret these lube instructions.
Drive gears run in the oil bath and won’t require lubricant change more than once a year. When changing, put down the head to a horizontal position and loosen screws on the gearbox.
Open the cover and place pan under the right lower corner of the gear box.
Slowly raise the head until the oil flows out.
Lower the head and wipe up excess oil.
Add lubricant until it is full.
Close cover and tighten screws.
I picked up the saw a couple of years ago and never "changed" the oil.
Now it is starting to drag and the motor is getting really really hot so
thought I'd better investigate.
There is no liquid oil in the gearbox there is some real thick sludge in the bottom of the box.
What should I use as a lube? I take it it should be a oil not grease.
This has been getting a lot of use, probable 2 hours a day for the last month.
Thanks for the help!!
Ralph
Ralph
